Zenith CruZer & Sonex Logs
Date:  9-10-2020
Number of Hours:  1.50
Manual Reference:  n/a
Brief Description:  Finish up panel wiring
More soldering of wires. Buttoned-up the remaining on-bench wiring I could do today. That included wiring the EFIS data port output to the transponder, warning LED to the EIS, other EIS data lines, etc.
Next stop is to remount the panel for the last time into the fuselage so I can run the remaining wires for engine system, ground wires, main buss, etc.
