Zenith CruZer & Sonex Logs
Date:  9-6-2020
Number of Hours:  3.00
Manual Reference:  n/a
Brief Description:  Misc Panel work
No actual real touching the panel, but all related.
Had to install the fuel selector valve in the console so I could connect the fuel lines to check for headset jack clearance. Pretty tight! Still not sure where I'll put them. Can't paint until I decide and drill.
Looked extensively for mini SPST switches; could've sworn that I had some, but no luck. Ordered new.
I was keeping my electrical terminals in a compartmented box, but was running out of room. Transferred all to a new, larger box. Transferred some washer head machine screws into the previously used compartmented box; it was a real pain to try to find something.
Tapped the fuel line fittings to get them to line-up in the fuel selector. Had to file notches in the console cover to accomodate the 3 screws holding the selector in the console.
Probably did other stuff but lost track....
