Zenith CruZer & Sonex Logs
Date:  12-17-2019
Number of Hours:  1.20
Manual Reference:  n/a
Brief Description:  Create exit holes for brake lines
The brake lines need to exit the fuselage close to the main gear in order to traverse down the gear leg to the brake calipers.
The factory recommends just drilling a hole and putting a grommet in it to protect the plastic lines.
I drilled the holes, then used a reamer by tilting the drill to create a "directional" hole. I then cut a length of 5/16" brass tube (2") to go in the hole, protecting the plastic tube. I will epoxy these brass tubes in place.
