Zenith CruZer & Sonex Logs
Date:  10-28-2019
Number of Hours:  0.40
Manual Reference:  n/a
Brief Description:  Drill and fit rear torque tube bearing block stop
No pics.
Several months ago I messed up the L-angles that mount to either side of the aft end of the torque tube to limit flaperon travel. I just could not get them drilled straight and had to order new ones.
Today I had a little time remaining so I was able to clamp the angles to the aluminum bearing backer. Why it didn't make sense months ago, I'll never know.
Drilled all 4 holes just fine.
