Zenith CruZer & Sonex Logs
750 Cruzer
C75-LA-2
Correctly mount MLG leaf
Another helper arrived this AM; I decided overnight that I'd just elongate one notch a hair to see if that helped the fit.
@2 son and wife helped me remove the improperly-mounted gear. I ground it out a bit and we re-tried mounting it. Perfect!
Re-installed pads and lower angles and tightened retention bolts. All is well. Never did call Zenith
correct orientation
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
