Zenith CruZer & Sonex Logs
Date:  4-26-2019
Number of Hours:  2.20
Manual Reference:  n/a
Brief Description:  Misc cleanup / sanding
No pics.
Spent time cleaning up the workbench after the painting session on the 22nd. The top surface was pretty rough, but then again it's high enough most folks won't see it.
Still, spent a bit of time sanding with 400 grit to smooth out the big offenders.
right side is perfect; no cleanup required. Might add a light second coat just for coverage.
Left side is almost as perfect, but I forgot (duh....) to wipe down that surface before painting; have a few spots with dust under the paint.
