Brief Description: Cleanup, rivet upper skin, rivet baggage back, pre
A lot of small varied tasks.
Finished riveting the upper skin to the top of the front crossmember. Cleaned up the rivet stems and drill shavings from the past several days work. Vacuumed-out the aft fuselage before things get closed-up.
Deburred and delabeled several small parts like gussets, seat belt anchors, etc.
Riveted the upper baggage back to the upper skin, then riveted the side channels of the baggage back to the fuselage sides.
Crimped a BNC connector to one end of the eventual ELT antenna coax cable.
