Zenith CruZer & Sonex Logs
750 Cruzer
C75-FA-2
Wrapped up right side, started top panel
Deburred right wing components C75-F-3-1 and F-4-1. Cleco'd into position to provide rigidity at the front of the skin during manipulation.
Marked and drilled the front vertical post (F-4-1) for the 1/8" thick L angle doubler. Up-drilled to #20. Riveted the two parts.
Moved R wing panel to the wing cradle.
Unwrapped the top skin; deburred all edges and all holes.
Deburred the 7 vertical and diagonal L-angle stiffeners and cleco'd into position.
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
