Zenith CruZer & Sonex Logs
Date:  10-28-2018
Number of Hours:  2.40
Manual Reference:  C75-FA-1
Brief Description:  Wrap up bottom panel; start side 1
Drilled-out 18 rivets so I could paint the flaperon motor bracket. letting it dry overnight. Installed AN3-4A nuts/bolts (4) in the lower vertical tail mount on the aft lower skin. Installed 10 nutplates with A3 rivets to allow mounting of the lower inspection panel. Deburred the opening for the lower inspection access hatch.
Unwrapped the left side skin panel (well, they're both the same; I just decided to make this one the left). Deburred ALL holes, both sides. Accessed all vertical and diagonal L-angles and laid them in place. Still have to deburr them and remove labels from same.
Fished thru the aluminum parts box to find remaining fuselage channel stock items.
Copyright © 2001-2021 Matronics. All Rights Reserved.
