Zenith CruZer & Sonex Logs
750 Cruzer
C75-KA-1
Prep left wing fuel tank
No pics.
Measured and marked the drill location for the fuel sending unit.
Drilled the opening for the fuel sending unit - 59mm hole.
Test-fit the sending unit.
Bent fuel sending unit float arm to match the zenith tank dimensions.
Deburred tank, removed metal chips.
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
