Zenith CruZer & Sonex Logs
Date:  7-1-2018
Number of Hours:  2.10
Manual Reference:  C75-WA-3
Brief Description:  Fold outer nose skin; prep for drilling spar; dril
Picked up from last night; folded-over (using ratched straps) the outer nose skin. Note that the skin is in final configuration where the nose skin overlaps the aft skin. However, for drilling the main spar, the aft skin has the pilot holes, so after pic 1 was shot, I removed the aft skin and positioned it on top of the nose skin. Cleco'd all into position.
Drilled the main spar pilot holes to #40; cleco'd every other hole. Went back over the holes and drilled all to #30, then one final pass to take to the final size of #20 to suppport A5 rivets.
Next steps are to remove the skins, debur, reposition and rivet.
outer nose skin folding into position
Drilled to #20 and cleco'd
