Zenith CruZer & Sonex Logs
Date:  5-16-2018
Number of Hours:  1.30
Manual Reference:  C75-WA-2
Brief Description:  Remove root nose skin
Well, I bit the bullet and decided to replace the cracked root nose skin. Had to drill-out the lower side rivets. I was a bit skeptical about doing this and ruining the holes because sometimes the drill bit will wander once it hits the inner steel mandrel.
I found a punch of the correct size and used a hammer to push out the mandrel stub, leaving nothing but aluminum rivet body holding the parts together. This was easily drilled-out with no damaged holes.
Removed the skin and cleco'd to the remaining new skin (both wings are identical, so I still have to order a new skin...)
I just hope the new skin fits as well as the old one did prior to removal!
No more skin!
No more skin!
Old on top of new in prep for drilling
