I applied some more body icing to a couple spots on the door and sanded them again. I then pulled the tape off. I still have to trim/sand a couple spots better, but I think I'm done with the windows. The next session, I'll have to work on filling the pin holes on the rest of the door surface.
I riveted the latches to the oil door and put a little micro on the rivets to cover them.
Janice sanded the door frame again on the cabin cover, as well as the rivet line on the bottom cowl, and the NACA vents. A little more mirco was applied to fit the interior panel a little bit better.
