Bob Leffler's RV-10
RV-10
Doors
11-22-2010
Left Door - Safety Latch
Drilled 1/2" hole for the door handle.
Cut the door and drilled the mounting holes for the planearound.com safety latch.
Epoxied with cabosil the two support squares into the door just outside of the saftety latch opening.
Support blocks to reinforce the door
Support blocks epoxied
Door handle hole drilled.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
