The saga of the multiple door customizations continue. Ivan mentioned that his iflyrv10 flush handles were too close to the door pin rod. I'm having similiar experiences. Brad assisted me in determining how to work through the issues. Unfortunately, I dropped a set screw on the floor and it's lost forever. I was able to get a replacement screw from Lowes and grind in down to the proper length.
Brad and I believe we've got everything dry fitted and working. This is why this is taking so long. We wanted to make sure everyhing worked and that we had a good working knowledge of all the parts from the various vendors and that they were going to play well together.
The last step we did today was to expoxy the flush handle into place. I'll probably put some fiberglass strips on the back for reinforcement.
A wedge holding the flush handle in place until the expoxy dries
