Bob Leffler's RV-10
Date:  6-12-2011
Brief Description:  Cowl
Brad assisted me with this task this evening. I had to take about 1/8" off the front of the bottom cowl for proper clearance for the spinner. Previously I had added about four layers of fiberglass. I sanded down to the lines that Brad had drawn a few days ago. This took it down to the first of the new flberglass layers. Because of this, I added another four layers for fiberglass this evening and then added peel ply.
The front still needs to have the edges contoured and all the holes filled.
Brad holding the cowl after sanding the front edge
Peel ply on the additional fiberglass layers
