I drilled a hole in the baffle to allow the the pruge fuel line to pass through. I installed a grommet to isolate the fuel line. I also installed stainless steel shields are the throttle cables on the forward side of the firewall.
Brad and I also removed the Skytec starter 149-12LS to be replaced with a Skytec 149-NL per Skytec's recommendation.
Purge Valve return line pass through in the plenum
