Brief Description: Battery Connections and Fairing Sanding
I spent most of the day working on the various power cabling to the battery and the ground power supply. I ran into an issue with the last ground terminal. The cable was too short to reach to terminal tool in the vice. I've been using a 3' piece of pipe to get enough leverage to swage the terminal. Unfortunately, with this last termination, that pipe is too long for use inside the fuselage.
While it's starting to sound like a broken record, Janice work on fairings again. Before leaving, we patch a couple places with some micro.
