Bob Leffler's RV-10
Date: 4-16-2011
Number of Hours: 1.00
Manual Reference: 46-07
Brief Description: Install Brakes
46-07, Steps 2, 3, 4, 5, & 6
Brad performed these tasks.
Setup the Left and Right Cylinder Assemblies. Apply a thread sealant, such as Lubon #404 or equivalent, to the pipe threads of the AN822-4D Tube/Pipe Elbow before threading them into the top of the Cylinder Assemblies (the Bleeder Valve will have to be moved to the bottom of one of the Cylinder Assemblies.
Slide the studs of the Cylinder Assembly into the Torque Plate, place the Back Plate behind the Brake Disk, then bolt the Back Plate and Cylinder Assembly together.
Make a brake line (from ATO-032X1/4) to run from the fluid fitting on the bottom of the fuselage to the fluid fitting on the Left Cylinder Assembly, Instead of this step, brake lines from Bonaco were used.
Secure the brake line to the U-1 00 1-L Main Gear Leg with "Friction Tape" (found at most hardware stores) in at least four places. First wrap the tape around the main gear leg alone, then wrap it around the brake line as well.
Left Brake
Right Brake
Brake Line adhered to gear leg
