I cut out a variety of holes in the leading edge today. This section is a little off plan due to the options that I'm installating that aren't in the standard plans.
I cut out the holes for the Duckworks leading edge landing lights, then filed and deburred the holes.
I rough cut the hole for the access panel for the stall warnig device.
I also cut and filed the hole for the stall warning vane.
I glued the template to cardboard for the leading edge rib guide for the placement of the plate nuts to mount the light support.
