Bob Leffler's RV-10
Date:  12-18-2006
Number of Hours:  0.50
Brief Description:  Avery Tool
Based upon advice from the Ohio RVators, Van's Air Force forums, the Matronics RV-10 list, and Troy Grover, I purchased the following tools from Avery Tools. As you can see, I deleted quite a few items from the standard kit.
I added both a pnuematic squeezer and a DRDT-2 dimplier. I also didn't go with the Avery 3x rivet gun, dimple dies, and riivet set.
One other thing that came out of attending the class at Grov-Air was the importance of using light weight air hoses and swivels. I added these to the Avery order.
I suspect the following will not be formated correct. It appears that Kitlog removes all spaces, carriage returns, and line feeds.
QTY Description
1 1022 3/32 pop rivet dimpler
1 550 3/32 vise grip dimpler
1 4704 1/8 rivet set
1 4720 1/8 double offset rivet set
1 4595 back rivet set SALE PRICE
1 500 fluting plier SALE PRICE
1 575 hand seamer SALE PRICE
2 200 cleco pliers (2 pcs) SALE PRICE
500 1016 3/32 clecos (500 pcs) (RV10 quantity)
250 1017 1/8 clecos (250 pcs) (RV10 quantity)
10 2019 3/16 clecos (10 pcs)
10 1012 1/2X1/2 side grips (10 pcs)
10 1014 1/2X1 side grips (10 pcs) SALE PRICE
1 1042 edge rolling tool
1 1412 Sioux 1/4 air drill 3600 RPM
8 40 #40 cobalt drills (8 pcs)
6 30 #30 cobalt drills (6 pcs)
3 21 #21 cobalt drills (3 pcs)
3 27 #27 cobalt drills (3 pcs)
2 19 #19 cobalt drills (2 pcs)
2 12 #12 cobalt drills (2 pcs)
1 1/4 #1/4 cobalt drill
1 12x40 12X#40 extension drill
1 12x30 12X#30 extension drill
1 1100 drill stop set (4 pcs)
1 19400 countersink cage/c'sink cutter set (w/ 5 c'sinks)
3 330 set of marking pens (3 pcs)
1 1245 12 inch flexible steel rule
1 1007 rivet gauge set (4 pcs) SALE PRICE
1 1008 rivet length gauge SALE PRICE
1 58337 Wiss offset snips left (Brand recommended by Vans)
1 58338 Wiss offset snips right
1 1046 speed deburring tool
1 22022 Royal multi-burr tool
1 3753 Scotch-Brite cutting and polishing wheel
1 710 curved tooth file (for aluminum work)
1 757 3/32 drive pin punch
1 758 1/8 drive
