Bob Leffler's RV-10
Date:  8-9-2009
Number of Hours:  4.00
Manual Reference:  SB 08-6-1
Brief Description:  Service Bulletin 08-6-1
Since my empennage is not mounted, I was able to skip a fair number of steps in the service bulletin. The following were the steps that I performed.
Remove the rivets common to the F-1014 Aft Deck, F-1010B Spacer, and F-1010A Horizontal Stabilizer Attachment Angle. After removing the rivets, remove the bolts. Remove the rivets common to the F-1014 Aft Deck and F-1032-L & -R Longerons forward of the F-1011D Attachment Bar Support Angle. Use a #30, 12-inch extension drill to remove the eight rivets common to the F-1014 Aft Deck and the F-1009 Bulkhead. Pull back the F-1014 Aft Deck and secure it in position with a rope, wire, etc.
Match-Drill #30 all of the holes of the F-1010C-L & -R Bulkhead Doublers into the F-1010 Bulkhead and F-1010A Horizontal Stabilizer Attachment Angle. Be careful to drill square to the bulkhead, particularly when drilling into the angle.
Rivet the F-1010C-L & -R Bulkhead Doublers to the F-1010 Bulkhead and F-1010A Horizontal Stabilizer Attachment Angle . Position the F-1010B Spacer back in place on the F-1010A Horizontal Stabilizer Attachment Angle, then cleco the F-1014 Aft Deck back in place. Replace the two AN4 bolts that secure the F-1014 Aft Deck to the F-1032-L & -R Longerons and, to maintain alignment while riveting, temporarily place AN3 bolts in the four holes in the aft deck that are used to secure the front spar of the horizontal stabilizer. Rivet the F-1014 Aft Deck in place.
I'm match drilling the holes in the doubler
The doublers all riveted.
The aft deck riveted back into place.
