Rivet the F-1044 Forward Fuselage Rib Subassembly and F-1083 Control Cable Bracket to the F-1068A Sub Panel Center. Rivet the F-1068B-L Sub Panel Side and F-1 045-L Forward Fuselage Rib to the F-1068A Sub Panel Center. Rivet the F-1068B-R Sub Panel Side and F-1045-R Forward Fuselage Rib to the sub panel center. Rivet the F-1071 Forward Fuse Top Skin to the Sub Panel Forward Fuselage Rib Subassembly using the rivets and riveting sequence. Rivet the F-1071 Forward Fuse Top Skin to the Sub Panel Forward Fuselage Rib Subassembly using the rivets and riveting sequence. Install the rivets in the rivet rows labeled "RIVET 6th" and "RIVET 7th" beginning each row with the most inboard rivet and progressing outboard.
No pictues today, since I took them in the marco mode by mistake and they're out of focus.
