Bob Leffler's RV-10
RV-10
Started Right Wing Assembly
Right Wing
13-2, Step 4. Attached the spar extension to the left spar and riveted in place with the spar splice plates
14-3, Steps 6 & 7. Riveted the flange bearing to the torque tube support brackets, then riveted the assembly to the first wing rib
14-3, Step 5. Riveting the flap hinge rib to the flap hinge bracket to the wing rib. There are three of these.
14-5, Step 1. Started assembly of the wing ribs to the right wing spar.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
