Bob Leffler's RV-10
RV-10
Continued dimpling
Continued dimpling.....
Did one of the elevator skins
Punched an extra hole in the trailing edge.
Consensus was to build on, since the cosmetic hole would be covered by fiberglass later. However, Brad noticed that the correct hole had a tear in it.
I ordered a new skin and it should be here next week.
The double dimple
A closer and out of focused shot
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
