Bob Leffler's RV-10
Date:  12-3-2012
Number of Hours:  3.00
Brief Description:  Taped gray areas on right wing
Todd, Janice, and I taped the layout for the phantom gray areas on both the top and bottom of the right wing. The photos are of the bottom of the wing. I forgot to take photos of the top before we rotated the wing.
Janice and I then headed back to the hangar. I forgot to bring the access plate for the aileron trim. Some of the primer on the spinner filled in the screw holes, so I opened them back up. I also picked up the wing tips lenses so we can make some adjustments on the wing tips that didn't become apparent until after priming.
Bottom Wing Root
Bottom Wing Root
Bottom Wing Tip
Bottom Wing Tip
