Bob Leffler's RV-10
RV-10
Doors, Cowl, and Scoop
I cleaned up the fiberglass edge around the right door window. I started sanding the primer coat on the inside of the door.
Janice coated the inside of the lower cowl and scoop with epoxy to protect them from any future oil leaks.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
