Janice applied some micro to the air inlet ramps on the cowl.
I worked on trimming the rest of the Aerosport Products interior panels and sanding the micro on the cabin cover door frames. Janice applied a little more micro on one of the corners.
Janice applied some body icing on the aluminum door pin guides.
I applied body icing around the oil filler door. I later sanding it. There are still a few problems that I hope to fixe with some epoxy tomorrow.
