Bob Leffler's RV-10
RV-10
Cowl, Doors, and Wheel Pants
Janice and I applied a coat of body icing to both door interiors again. I'm hoping this will be the last coat.
Janice started sanding the nose wheel pant.
I rough sanded the cowl. It's starting to look like the two halves were made for each other. Too bad that they didn't come from Vans that way.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
