Bob Leffler's RV-10
RV-10
Vertical Stab Fairing and Battery Ground Terminal
The PPG sales rep stopped by the hangar tonight so I didn't get as much done as I liked.
Janice finished sanding the fairing on the vertical stab. I shot a coat of primer to see if it was done. It looks good. (Finally!!!!!)
Janice also helped me with the terminal for the ground cable. This is the last fat wire that needs to be terminated.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
