Bob Leffler's RV-10
RV-10
Installed brake lines
Installed the new brake lines. I still need to install something to keep the two lines from rubbing where they cross over.
Moved the upper fuelage assembly to the hanger.
Started to work on installing more insulation.
Cutting my finger on the stainless foil and having the OSU game on, didn't help with productivity.
Lines run to the parking brake
Brakes lines run through the tunnel
Brake lines run underneath the seats
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
