Bob Leffler's RV-10
RV-10
Misc Sub Panel Supports
I worked on the doublers for the comm panel opening in the subpanel. After match drilling the holes, I primed the part, and the riveted them to the subpanel.
I also made some brackets to hang the VP-200 from the ribs behand the subpanel.
I also helped Tom Webster with his annual.
Brackets cut for the VP-200
Primed doublers
Doublers installed
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
