Zenith CruZer & Sonex Logs
Date:  1-13-2011
Number of Hours:  1.00
Manual Reference:  aerovee
Brief Description:  Exhaust Trial / Trimming Case Boss
Wasn't going to do too much tonight, and in reality, I probably didn't....
When I installed the lower oil baffle the other night, it was "bowed" in the middle such that the oil cooler would not fit flush on the baffle. Tonight I removed the baffle and trimmed the offending casting boss on the bottom of the engine case (yes, I see all the cutting dust - need to clean that out). Used a cutoff wheel in the dremel tool.
I re-installed the (broken) baffle and the cooler now fits flush. Trimmed about 5/32" off of it.
Prior to that, I tightened up the right exhaust header. This was the one that was spread a bit too wide. Sonex said the bolts would pull it in, and they did. I then dug out the exhaust extensions to test-fit them and make sure they didn't interfere with anything - all's fine there as well.
Obtained 3/16" fast-on terminals for the coils (all the other terminals are 1/4"). Researched availability of 5/16' terminals to act as the grounding lugs for the coils. Radio Shack didn't have them, so I'll check the home centers tomorrow.
Oil cooler lower baffle and exhaust
Shiny boss in the center trimmed
