Zenith CruZer & Sonex Logs
Sonex
n/a
Firewall / Gascolator Stiffening
My gascolator bolts directly to the firewall, and, like most, it oil-cans a bit, as well as the gascolator itself flexing on the firewall.
I made up a stiffener plate of two .025 scraps of aluminum and cut a hole in the middle to go around the gascolator fuel pipe and mounting bolts.
Just laying the stiffener in place, it appears that it will help keep the gascolator from flexing, but the larger firewall area still oil-cans a bit.
Next, I'll reinstall the motor mount and see about adding a 1/8" piece of aluminum on the engine side to help minimize the oil-canning.
.050 Stiffener Plate
Just laid into position around the gascolator
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
