Zenith CruZer & Sonex Logs
Sonex
SNX-W05
Right Flap Drill / Deburr / Prep for Rivet
Drilled skin-to-rib pilot holes, upper & lower skin surfaces. Up-drilled to #30.
Set up jig to space hinge .057" from flush with skin; drilled hinge. Up-drilled to #30.
Stripped protective plastic from rivet areas on skin. Disassembled all parts.
Deburred ribs. Deburred all skin surfaces inside and out.
Deburr hinge.
Cleco all together in preparation for riveting.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
