Zenith CruZer & Sonex Logs
Date:  3-5-2009
Number of Hours:  1.20
Manual Reference:  SNX-W05
Brief Description:  Pilot Drill Right Flap for Ribs
Marked rivet spacing on leading edge (vertical) of right flap.
Pilot drilled to #40 all holes, including the rib rivets marked-out last night.
Positioned ribs (4) against the leading edge. Pilot drilled holes, cleco'd. This will secure the ribs into position for drilling the upper/lower skin surfaces to the ribs.
Verified that red rib centerline visible thru skin pilot holes.
Next steps: Drill upper/lower skin-to-rib pilot holes. Pilot-drill hinge-to-flap holes. Updrill all to #30, then remove, deburr, and rivet.
