Drilled all rivet holes on SNX-T09-01 to #30 for CCP 44/46 rivets. Drilled bolt holes for AN3 bolts to 3/16". Will have to go back over them with a numbered bit (#12) since 3/16 results in the hole being too tight for the bolt. Pilot-drilled SNX-T12-05 and SNX-T12-06, then up to 3/16" for botls. Fabricated SNXT09-03 temporary spacer - needed to be 1/8", but I used scrap .025 material (5 layers) to get the same thing.
