Zenith CruZer & Sonex Logs
Sonex
13 - Engine
2-24-2011
aerovee
Engine FWF Wiring
Installed EGT probes into exhaust stacks.
Routed / re-routed wires on the right side of the engine. Relocated the oil pressure sending unit wire from on top of the engine over to the side so that it can be braced against the intake manifold.
Started wiring CHTs to the RDAC.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
