Zenith CruZer & Sonex Logs
Sonex
13 - Engine
2-22-2011
aerovee
Install Exhaust Flange Gaskets
Removed the exhaust manifolds and installed thick flange gaskets. Had to bend both manifolds out a bit (grunt!) to fit the gaskets in between the heads and manifolds.
Torqued all bolts to 13 ft lbs.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
