Brief Description: Install Right Side Applique / Rivet Wingtips
Today I installed the right side applique graphic that I had designed for me. I wanted just a bit more than the standard painted cowl and other fiberglass, so I got a bit whimsical.
The color match looks better to the naked eye than it did to the camera. It wasn't 100% to start with, but was close enough.
This was a wrap-type product in that it shrinks around rivets and screws with heat application. Went on better than I thought; no wrinkles, at least!
Also riveted both wingtips. Used AAP-42 rivets (100% aluminum) to allow easy drill-out if I ever need to change a strobe bulb.
