Received the new hardware I ordered in order to finish out the windshield; the plans-spec'd MS24693-S48 screws were too short; needed S50s. They arrived, I installed. Windshield done.
The Nitro-Stan scratch putty I used the other day is OK for pinholes and scratches, but not very good for filling separation lines, like between the halves of the wheelpants. Obtained some new stuff that's a 2-part mix. Filled some rivet lines on one of the cowl halves; seems to sand OK. Will sand some more after it cures overnight.
Sanded quite a bit on the two wingtips. Had some pretty bad orange peel. One more light color coat and it will be ready for clearcoat.
