Zenith CruZer & Sonex Logs
Date:  2-14-2011
Number of Hours:  1.00
Manual Reference:  aerovee
Brief Description:  Sensor wiring
Fabricated wire harness for oil temp & pressure. Installed and connected to RDAC. Connected fuel level sensor to RDAC. Evaluated cowl cuts to accomodate prop hub.Re-did RDAC secure power supply wiring (had excess). Routed and secured tach sense wiring from voltage regulator to RDAC.
