Zenith CruZer & Sonex Logs
Sonex
SNX-T01
File some more / Rivet Lower Rudder Hinge
Finished filing the rudder control horn to provide 25 degrees of swing in each direction.
Up-drilled the lower rudder hinge to #30 for riveting. Removed parts; deburred & riveted.
Close to finishing up the tail!
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
