Zenith CruZer & Sonex Logs
Date:  3-27-2010
Number of Hours:  2.30
Manual Reference:  SNX-T01
Brief Description:  Vert Stab Trimming
Spent the entire time taking the vertical stabilizer on and off in order to trim it to allow full up/down elevator travel.
First turned around some improperly installed AN3-7A bolts that would have interfered with the control horn. Then I trimmed the size vertical stabilizer skins. Next to be trimmed was the bellcrank area on the control horn cross tube. Then on and off trimming and testing, trimming and testing.
Long, laborious process.
