Zenith CruZer & Sonex Logs
Sonex
SNX-C06
Seat Pan Hinge Locating
Located and pilot drilled the piano hinge that mounts just above the main "bend" line on the seat pan. This hinge will mate against its other half that's already mounted on the seat belt attach angle in the fuselage.
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
