Zenith CruZer & Sonex Logs
Sonex
SNX-W06
Right Flap Detail Work
Started the right flap tonight.
Got out the parts, dug around for the flap drive plate, ribs, etc.
Marked out cut measurements on the right flap. Drilled 1/8" relief hole prior to cutting drive plate access hole.
Positioned, drilled, cleco'd and up-drilled SNX-W06-05R drive rib assembly.
Flap Marked Up
Drive Rib Cleco'd
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
