Zenith CruZer & Sonex Logs
Sonex
SNX-T03
Horiz Stab Aft Main Spar
Test fit / clamped / drilled / cleco'd the left and right channel sections (SNX-T06-04) to the aft main spar for the horizontal stabilizer. Could only fit one SNX-T03-03 angle fitting because, as noted previously, only one was shipped with the kit.
Aft Main Spar, center section detail
Overall View Looking down the length of the spar
750 Cruzer Home
Sonex Home
3017
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
273
02 - Wing Spars
03 - Wings
119
464
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
273
Systems
464
