Discovered yet again (duh) that I made only one piece for two parts that each required a left and right side. Cut to length SNX-T03-04 and SNX-T03-06, the channel stock for the front and read horiz stab spars.
Fab'd both L & R sides to the SNX-T03-04 aft spar channels; bent 90 deg angle, and drilled pilot holes for ribs. Did initial test fit placement onto aft spar.
Drilled out mounting holes for front and aft horiz spars to 1/4" and 3/16" as applicable.
