After cleaning, deburring etc. I riveted the right wing tip in place today, then I started filling the gaps with automotive filler, went through a few iterations of filling and sanding. Then I decided to install the aileron belcrank cover plate, another thing I had left for later. I had already made the plates so this just required 4 holes to be drilled, done.
