Brief Description: Completed R wing tip installation, started L tip
Did some more filling and sanding of the right wing tip today, that should be enough. Put the wing back in the stand, took some pictures and then started working on the left wing. First installed the cover plate, then started cutting the flanges etc. off the tip and fitting it to the wing.
